Automation ActiveX for msGraph isnt working
Im using the report generation toolkit and when Im trying to change a graph in a word document with the "Word Update Graph.vi" i get an error "Not enough storage is available to complete this operation.
in Word_Update_Chart.vi->Word Update Graph.vi". It seems that there are some objects not registered in my system. Im using windows98 and Office2000. Can U help me?
(2,985 Views)
This does sound odd. Are you able to plot the graph to your Word document without any errors? If so, then the graph is registered on your system. I would try different parameters for the Word Update Graph VI and see if any other settings make it work correctly. It could be that your particular set of choices is causing the error for some reason. Try running your VI without Word Update Graph first, see if it runs, and then try it with different parameter combinations for the Word Update Graph. Let us know what you find.
J.R. Allen
(2,985 Views)
Hi JRA,
I tried several types of inputs data also for the row & column headers but got the same error message �not enough storage ��. On a different computer this is working, maybe it is something about my computer configuration, I had consulted with our system administrator but he could help me. I debugged my vi into the �word update graph.vi� and I saw that the error comes from the �word_update_graph.vi� which is called dynamically what does it means? The graph that I�m trying to change is already at the report because I�m using a template report and wants to just change the data of the graph for each report.
(2,985 Views)
After reading this information, I would guess that you need to register the msGraph on your computer. If it works on another machine, then the VI must be fine. Make sure that the ocx is registered on your computer and then run it again.
J.R. Allen
(2,985 Views)
