Automating Interaction with MPLab IDE using LabVIEW
I am using MPLAB Real Ice as a debugger for my code. I need to set certain predefined breakpoints in the IDE which I am planning to automate by giving line number of code to LabVIEW and then LabVIEW should send the command to set that breakpoint. While exploring options in LabVIEW for Inter-Application communication, I came across via TCP ans via ActiveX.
 Which is the better option in this scenario? What approach should I start with? Please note that I am trying to communicate only with the IDE and not Hardware.
(4,631 Views)
Does Microchip document their ActiveX interface? I briefly looked into this many years ago and MPLAB didn't really have very good automation hooks. In my case, we were doing automated builds and the workaround was to use a command line utility instead. Ask Microchip what they recommend. My gut feeling is that if they have an ActiveX interface, that will be the easier to use.
(4,601 Views)
Hi Takki,
I am automatizating a laser instrument, and it has their own classes. Do you know how to initialize the ActiveX server (locally) in LABVIEW?
thanks,
(4,501 Views)
