Automatically on and off Boolean switch
My program needs to ramp up to a particular value and then ramp down, and this has to go on forever. I can use a switch to manually do this. If this switch works automatically, then my program will work continuously. Can someone tell me how to make automatically on and off switch?
Message 1 of 10
(5,639 Views)
Fortunately, LabVIEW is a real programming environment, so this can be done easily. The solution depends on how you do the ramping, so show us your VI.
Message 2 of 10
(5,632 Views)
Instead of a button, store a flag in a shift register and you can do just a little analysis to set or clear the flag so you know which way you are ramping.
Message 3 of 10
(5,629 Views)
hi,
I need to make ramp(Boolean) on and off forever. True case in the case structure is a ramp up and false is a ramp down.
Message 4 of 10
(5,620 Views)
hi,
sorry for not uploading the vi.
Message 5 of 10
(5,618 Views)
Sorry, I don't quite understand the code. Apparently this runs under RT. Why these bewildering constant conversion between datatypes (FXP, SGL, I16, etc). What the reason for the +1followed by -1 in the outer false case?
I'll have a look....
Message 6 of 10
(5,601 Views)
Here is a quick draft. I would probably pre-compute the ramp and then simply index into it.
Message 7 of 10
(5,595 Views)
I can't open in LabVIEW 16.0
Message 8 of 10
(5,452 Views)
Saved back to LV 14.
Message 9 of 10
(5,443 Views)
Message 10 of 10
(5,425 Views)
