Automatic zoom in
Dears,
I would be grateful if someone can help me to know how to do automatic zoom in when I am running the code without using the picture's tools. I've tried to find any helpful property in the property node but I couldn't find something can help me to solve this issue. Any support? thanks in advance
Message 1 of 12
(6,013 Views)
Not sure what you mean by "automatic" zoom in.
But if you turn OFF AutoScaling (both X and Y), then you can set the XSCALE.MIN, XSCALE.MAX, YSCALE.MIN, and YSCALE.MAX from properties.  The graph will then show that range.
From there you can implement some sort of zoom if you want - have a center point and a smaller and smaller deviation to provide a zooming-in appearance.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 2 of 12
(5,965 Views)
Hi Steve,
Thanks for your feedback, Can you please tell me how to turn off the autoscaling? Thanks in advance
Regards
Message 3 of 12
(5,909 Views)
Did you try looking in the properties of the graph?
Steve Bird
Culverson.com
LinkedIn
Message 4 of 12
(5,904 Views)
yeah, I haven't seen something related to auto scale, Have you?
Message 5 of 12
(5,901 Views)
Accepted by topic author Al-rawachy
It's under autoscale.
GCentral
Message 6 of 12
(5,894 Views)
OOh, thank you, I thought you mean inside the property node!!
Message 7 of 12
(5,890 Views)
Excuse me, I wonder if there is a way to enter the values of zooming scale for x and y coordinates by using the code rather than doing it manually? Thanks in advance
Message 8 of 12
(5,885 Views)
To change the limits of the scale, you can use the property node with the entries 'XScale.Maximum' or 'YScale.Minimum' and so on. They're under X Scale/Y Scale > Range > Minimum/Maximum.
This forum post describes autoscaling programmatically. 10degree's post seems particularly helpful. I'm sorry for the picture earlier - I had thought you were trying to avoid property nodes. My mistake!
GCentral
Message 9 of 12
(5,879 Views)
you are amazing. thank you
Message 10 of 12
(5,875 Views)
