Automatic reconnect MS Sever SQL connection
Dear colleagues,
Please help me about how can I do the automatic reconnect SQL server connection after lost.
Now the "DB open connection" I did at once before "while loop" and I don't want put into "while loop" in order to leave growth memory consumption
(9,260 Views)
Opening the connection in the while loop should not increase memory consumption, provided you close  each connection after use.
In your case you could close and reopen the connection in the while loop only if an error has been detected.
I usually avoid keeping a connection open it not strictly needed: I prefer to open-use-close the connection each time.
Marco
(9,256 Views)
Dear Marco
With your "open-use-close connection" how much long application works?
Simply my application is working in 24/7  (Smiley Happy)  and I try to minimize memory consumption...   Unfortunately LV can't working in uninterrupt mode
(9,234 Views)
THe overhead for the open/close is very little. We have not observed any issues when using this method.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(9,232 Views)
Opening/closing the connection to a database placed in our local network takes e few ms.
Since we are executing queries about once every 30s we chose the open-query-close approach (which has a "bult-in retry" in a certain sense...)
A look here could help confusing the ideas about what's better 🙂 :
http://stackoverflow.com/questions/312702/is-it-safe-to-keep-database-connections-open-for-long-time
Marco
(9,227 Views)
Accepted by topic author Current_93
We were closing and opening a connection every time and we decided to change because the virtual memory increases considerably. So,  we opened the connection before the while inserting a case inside the while which detects an error with the communication and if thats the case reconnect the communication.
(9,201 Views)
how about a SQL state machine, see attached
(7,459 Views)
