Automated EXE UI interaction/button press
Hi, I have two EXEs.  If an event occurs in one of the EXEs, I want it to open up the other EXE (which I will open using the command prompt) and then I want it to press a button (boolean control) on the second EXE programmatically.  I do not want to pass any boolean values between the EXEs. I just want to have it press the button.
Is this possible? by any means, with or without labview.
(1,370 Views)
There are many UI automation software available, one such open-source one is SikuliX
Santhosh
Soliton Technologies
(1,359 Views)
