Auto-populate unit tests
I'd like to dynamically include unit tests (lvtest) in a project A from various other projects B1, B2, etc., i.e., when I add a new test say in B2, it gets added to A automatically.
"Auto-populated folders" don't seem to work here: unit tests return with an error "class cannot be loaded" (some other text in German).
It seems to me that unit tests get corrupted during auto-population.
When I add a unit test manually from project B2 (via add & browse), the unit test runs without errors.
Any idea or workaround?
Peter
(3,540 Views)
Hello Peter,
could you please upload the error message for us?
E.g. I am german and can say something about it, or do some research.
Thank you,
have a nice evening,
Best regards!
Christopher W.
Intern Application Engineering | NI Certified LabVIEW Associate Developer (CLAD) | NI Germany
(3,515 Views)
Hi Christopher,
thanks for your support.
We found (in our setup) that
  1. (ERROR) All unit tests of a project (added within this project or auto-populated from other projects) result in an error ("Mögliche Ursachen: LabVIEW: Die Klasse konnte nicht geladen werden.") if the unit tests assume "cyclic inheritance dependency"; by cyclic inheritance dependency I mean that the current project contains a class C such that C inherits from a class A and A and its unit tests are located in an auto-populated folder;
  2. (SUCCESS) Unit tests located in auto-populated folders without cyclic inheritance dependency result in the same execution as in their originating projects -> for us the expected behavior.
    Does it make sense to you?
Peter
(3,497 Views)
Good evening Peter,
unfortunately this does not make sense for me. Could you create a minimal example project which shows the same behaviour and upload this here?
I also have to say that I don't have much experience with classes and inheritance. But I'll give it a try!
Looking forward to hearing from you,
best regards!
Christopher W.
(3,484 Views)
This one is surprising me as well and I just can't put my finger on why you would want to do this.
Library A has requirements, code, and some unit tests to prove the code does what you wanted it to.  Why are we talking about project B or adding coverage for project A requirements outside project A?
"Should be" isn't "Is" -Jay
(3,475 Views)
@Jeff: because there may be a dependency between A and B such that if B is changed, the unit tests in A may not be PASSED any longer. Of course, I can open A and check manually but what if I have tens of dependencies that I don't want to check one-by-one. That's why, I thought, one can auto-populate the tests of dependent projects and automatically re-execute them in a remote project.
@Chris: I'll try to reproduce the scenario in a dummy project.
Peter
(3,463 Views)
