Auto-Update File Path Name
Hello! I am currently trying to create a basic program that will save oscilloscope data to a file. I have it all working correctly, but ideal I would want to update the file name every time I run the program. So I press run, I trigger my source, the function(s) plot on the waveform chart, and it auto-saves to a specified location. Then, the next time I run it, it saves to the same location with a different name (e.g. data_1 then data_2, data_3 etc...). Would there be a way to do this while simultaneously keeping everything I've done so far relative consistent? I really only want to change the file path part of the block diagram. Thanks!
(2,160 Views)
Try "Create File with Incrementing Suffix"
(2,132 Views)
Was going to mention the same thing, but I will instead add that this is in the "Advanced file funcs" folder of the palette, under "File I/O".  Or, you can browse to it at "<vi.lib>\Utility\file.llb\" in your LabVIEW folder.
Link to help page
(2,115 Views)
Thank you so much! I will work on implementing this.
(2,074 Views)
