Auto-Update ActiveX-references
i have an ActiveX-file that i can use by inserting an ActiveX-Container and then inserting the registered object in this container.
After this i have some SubVis where i pass the reference in and out.
The problem is now: when i change the activex-file (add functions...) then i first have to re-register it in windows, re-insert in the container.
But also in ALL of my subvis i must click on the referecence and "select ActiveX-class".
How can this automatically be done? The reinserting once in the container is ok, but also in all subvis?
Thanks for all help
(3,337 Views)
Why would you have the ActiveX container in the subVIs? The subVIs only need a reference to the ActiveX class on which they need to operate. The container should be in the top-level VI only.
(3,324 Views)
Yes, i only have the container in one vi. In the other VIs are only "Automation references".
But as soon as my activeX-file changes (new registered to windows), the references become invalid and i have to click on each reference an must select in the popup "select activeX-class".
Message Edited by OnlyOne on 07-28-2009 09:38 AM
(3,322 Views)
