Auto DAQ configuration
Can I make Labview Executable to auto configure MAX Analog Input Channels without user configuration. i.e. If I make a stand alone application which has five analog input channels, if I want to use the stand alone application on other computer(which has NIDAQ instaleed), is it possible that Labview6.1 stand alone application generated analog input cofiguration automatically!!!
Kishor
(3,458 Views)
I think that all you have to do is include your niconfig.daq file and install it to the system folder (i.e. c:\winnt).
(3,458 Views)
I tried to include nidaq.daq file, it did not work!!!
(3,458 Views)
How did you include it? Did you specify it as a support file and did you specify where to install it? I'll admit it's been a while since I've done this, but I think that's all I did.
(3,458 Views)
Check out this knowledgebase for the steps of porting the DAQ configuration to another computer.
How Do I Port a DAQ Configuration File With an Executable?
http://digital.ni.com/public.nsf/websearch/CB83B101E19EF83086256A3E0054206C?OpenDocument
Todd D.
NI Applications Engineer
(3,458 Views)
