Authentication syntax for HTTP GET method using TCP functions in Labview on linux
Currently, I am trying to communicate to web server. I have Labview installed on a Linux machine. The HTTP function blocks and other labview functions do not work. Hence, I am building a HTTP code string using TCP functions (port 80) to talk to the web server. I am successfully able to fetch a response from web sites (example www.ni.com) from my vi. However, when I try to communicate to my web server, it does not work. It requires an authentication. I am able to open http://ipaddress in my browser from my machine using username and password. Can someone help with Authentication string requirement for GET method?
so far the string is:
GET /index/ HTTP/1.1
Host: http://xx.xx.xx.xx
(7,600 Views)
Hi SS21,
this link should help to solve your problem.
Mike
(7,546 Views)
An easy option would be to try http://user:password@server syntax for the URL.
Else I posted a Twitter fetcher once (won't work anymore since Twitter moved to Oauth authentication) at LAVA. Based on code from @cloew.
The code is part of this LLB.
Ton
My LabVIEW Ideas
(7,539 Views)
Thanks for all your replies.
MikeS81, your link helped understand the authentication structure, I have added the basic athentication string as part of my GET method string.
TCPlomp, the Base64 conversion in your LLB looks like something I can definitely incorporate for my username and password strings for authentication. I really appreciate you sharing this part of the code.
I will definitely try it out and hope it works.
SS21
(7,523 Views)
Thanks for all your help. It works!!  Smiley Happy
(7,473 Views)
