Attempting to use change detection with USB6525 as generated event
9.7 i think (already left work at this point)
thx
Message 11 of 20
(2,838 Views)
I'm still stuck swinging on this stinking problem-
this is the error- clearly stating that no IO line has been chosen to detect changes on...
and this is the code shot of the property node that clearly wires in MIO1/port1/line0 as the line to detect rising edges on...
This same exact code works on another computer with the same LV/MAX versions and a USB6525... I'm now going to try switching the USB6363 to the other computer...
-pat
Message 12 of 20
(2,826 Views)
Accepted by topic author plyons.gks
Try doing it this way:
Best Regards,
John Passiak
Message 13 of 20
(2,779 Views)
John-
thanks!, I was planning on posting up the solution after finally getting some help from a senior app engineer at NI (but im so busy I practically forgot about this post).  I also learned that the 6363 only allows for change detection on port 0 it seems...
Thanks again
-pat
Message 14 of 20
(2,770 Views)
You may configure non-buffered change detection on the other ports (like this):
Best Regards,
John Passiak
Message 15 of 20
(2,766 Views)
nice!
thanks for the info!
what is the name of that vi you added there?
-pat
Message 16 of 20
(2,762 Views)
DAQmx Configure Input Buffer.vi
Best Regards,
John Passiak
Message 17 of 20
(2,759 Views)
When running this sample, I get an error about not being able to unregister for events because a task is running. So I wire the error out from 'Clear Task' to the error in of 'Unregister...'. Now I get error 1, 'Input parameter is invalid'. I wired the 'Event Registration Refnum' wire through all of the cases, and still get error 1. How do I clean up properly?
Message 18 of 20
(2,731 Views)
That is interesting...
Upon wiring the error cluster, I notice on my system that I do not receive the errors you are reporting whether I call unregister before or after stopping and clearing the task.  I am using LabVIEW 2011, DAQmx 9.7.5, and a USB-6251 (I happened to have this plugged in to my system).  I'll admit though that my use of the unregister without any error cluster was a bit lazy.
Error 1 is what you would get if you try to unregsiter an event which has already been unregistered--it sounds like perhaps the DAQmx Clear Task is unregistering the event for you, though I'm not positive and haven't heard of this before (what version of LabVIEW / DAQmx are you using?).  You didn't mention the other error code, but it sounds like the driver is telling you that the event can't be unregistered without first stopping the task (which is fair enough I suppose).
With this in mind, I would try calling unregister after stopping the task but before clearing it, something like this:
If this is indeed the way to explicitly unregister DAQmx events nowadays, then NI needs to update their shipping example:
https://decibel.ni.com/content/docs/DOC-25103
Best Regards,
John Passiak
Message 19 of 20
(2,722 Views)
This works. LV 2013 SP1, DAQmx 9.8.0.
Thanks and kudos 🙂
Message 20 of 20
(2,717 Views)
