Attaching accelerometer sensor (h3lis331dl) with USB 6008
Hello everyone, I am a new user of USB 6008. I want to use h3lis331dl, an accelerometer sensor with USB 6008. Can anyone guide me through the procedure?
(876 Views)
H3LIS331DL is a digital accelerometer with only I2C/SPI output interface. USB-6008 is not capable of doing I2C/SPI communication.
Here are some alternatives:
1. Use Arduino. See H3LIS331DL Accelerometer Breakout Hookup Guide
2. Use NI USB-8452. Using I2C with LabVIEW and the USB-845x
https://tmesystems.net/
(852 Views)
Another thing for you to consider.  A number of years ago, I "advised" a group of BME seniors doing a capstone project to create a "paralysis sensor" for use by anesthesiologists during human surgery.  There is a test called "Train of Four" to monitor paralysis during surgical procedures -- you deliver a train of 4 small pulses to a peripheral nerve (electrodes on the skin) and count the number of twitches you see in the muscle.
Their idea was to put a small accelerometer on the muscle (taped down) and graphically display the acceleration pulses for the four twitches.  These accelerometers delivered X, Y, and Z as voltages, with (I believe) a gain of 0.5 V/g and an offset of 1.5 V.  The other interesting fact was that gains and offsets were ±10%.  To my chagrin, this rather large and unknown "uncertainty" in the 6 parameters of the accelerometer caused noone on the team to ask "How do we calibrate this device?".  They did get that they should make it "orientation-independent" by computing the length of the "acceleration vector", but were not bothered by the fact that when the accelerometer was not moving (flat on a table), you did not get readings of Z = ±1g, X = Y = 0g.  Oh, well, at least they could use a USB-6008 ...
Accelerometer chips are fairly inexpensive.  You should be able to find an Analog chip which outputs voltages instead of SPI or I²C.
(837 Views)
