Asynchronous process in plugin causes automatic rollback of script actions
I have a dialog in the attached plugin I'm creating, and it has an asynchronous event handlercall, which also calls a second asynchronous event handler) to handle display of a string on the FP. Even though these processes appear to be complete by the time the scripts are done executing, the script actions are rolled back. If I disable the second (nested) async call, I can get the scripts to not roll back most of the time, if I insert sufficient delay between at the end of the execute script VI.
Two questions:
1. Why are my scripts being rolled back, even though "Fail transaction?" is false?
2. Can I prevent the transaction recording so as to circumvent the rollback?
3. Is it not allowed to have nested asynchronous calls within a plugin?
Plugin function: Right-click on any cluster node to get "Unbundle..." and "Bundle..." dialogs, or add, remove, and rearrange named (un)bundlers via dialog.
_____________
Creator of the BundleMagic plugin for LabVIEW!
(2,809 Views)
I have highlighted the disabled code in the dialog (Cluster Item Selection_DIALOG.vi) in case anyone would like to try setting the bad code free.
_____________
(2,852 Views)
Can you try the fix posted here and see if it solves the issue?
https://forums.ni.com/t5/LabVIEW-Shortcut-Menu-Plug-Ins/Bug-Fix-for-ALL-Right-Click-Menu-Plug-Ins-LV...
(2,833 Views)
This fix did solve the issue. I will post an updated version of the plugin, along with an installer which installs the patch VI provided.
_____________
(2,806 Views)
