Asynchronous call: Checking if the sub-VI is running.
@VinnyAstro wrote:
@FireFist-Redhawk wrote:
Your only issue with the asynchronous call method was that the user could press the help button multiple times and multiple windows would come up, right? Or was there something besides that?
Yep.
I thought of disabling the button when the window is open, but I kinda didn't want to do that. My idea behind it is that if the user have a lot of windows open at the same time and don't want to bother finding the info one, then he can just click again on "info" and the info window would: 1. If it is not open, open in front; 2. If already open but minimised/hidden somewhere, Pop-up in front (and not re-open again)
I might be nit picking here, but I feel that it would be a normal and most natural behaviour from an application showing a poping window : Opening/showing up on a click on a button and closing ether by using the cross or clicking on closing button.
Also, the thing is, for now I'm doing this for a relatively easy application, which is just opening a window displaying a static message, but later I will most probably have multiple windows displaying various dynamic informations. I just figured out that training first on a simple application would be better 🙂
Well, don't open a new VI reference each time. If you reuse the 1st one, it'll refer to the same window. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 26
(1,254 Views)
Check this out and see what you think. Essentially, you build out the logic in your main VI to do different things based on if the help window is already open or not. And in your help window VI, take the queue from your main VI as an input so when user closes help window, you can update a Boolean flag (which exists in the data cluster of your main VI) that stores whether the help window is running or not.
First three images are in main VI, last is in help window VI.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 22 of 26
(1,252 Views)
Ah that's a cool idea! I haven't thought of taking the Queue as an input. I'll try it out !
Message 23 of 26
(1,238 Views)
Just to complicate things a little bit, you could always make the choice to display the pop-up as a choice in a custom menu.  If a menu event occurs, it is determined that the menu item changed, and it is selected (has a check mark) display the pop-up, if no check mark, don't display it.  That way, you won't have to worry about multiple button presses.  As a cleanup, you can programmatically uncheck the menu item to trigger the event to close the pop-up.
Bill
CLD
(Mid-Level minion.)
Message 24 of 26
(1,231 Views)
But... I'm not doing this already... Or am I? 🤔
Message 25 of 26
(1,222 Views)
@VinnyAstro wrote:
Yep.
This isn't nit picking at all. From a UX perspective (and IMHO), that is the best possible way of handling a help window. And that is basically how Detailed Help in LV works too. I would hate if it opened a new window everytime.
Redhawk
Message 26 of 26
(1,215 Views)
