Ask user to enter information and have a "press when done" option on FP - LabVIEW 2019
One should welcome adversity as an opportunity to excel.
(2,246 Views)
Accepted by topic author Daddy-O
Hi Daddy-O,
Create a simple VI with an event structure (no loop needed). Place the OK button (boolean of your choice) and configure the event structure to handle value changed. Put your cluster (control) inside that event frame, and wire it to a cluster (indicator). Also add error in / out.
Now go to VI properties (Ctrl+i) and find "Window Appearance". Set it to Dialog. Now you should be good to go!
P.S. I also like to add a "Cancel" button, which will have empty / default data wired out, as well as a "Canceled?" output that is hidden.
(2,209 Views)
Thanks so much. I think I had thought that into being complicated. I appreciate your help. Have a great day.
(2,162 Views)
