Ask a question about CDB data type storage format
According to the information I found, CDB means complex number, double precision floating-point type, my understanding is that the width of the real part and the imaginary part both are 64 bits, then the width of a CDB is 128 bits (that is, 16 bytes)
I convert CDB array into CSG in LabVIEW, and then save it as bin file, which can be read correctly in MATLAB, as shown in Figure 1.
However, if I directly save the CDB array as a bin file and read the file in MATLAB (see Figure 2 for parameter configuration), the data obtained is incorrect.
Please point out why?
(1,381 Views)
The Write To Binary File, by default, prepends the array length (I32).  That might be causing a file offset error.  There is a Boolean input on the Write To Binary File to remove that.
Note that you are getting this error with both of your files.  It is just not as obvious with the CSG file since a single value is 2 32-bit values.  So you signals are probably actually flipped.
(1,372 Views)
