Arrow indication with text on graph
is it possible to insert a arrow in the graph point at the point where i would want it,
like, doing a testing. if everything go smoothly, the line in the graph will be smooth(not straight line).
if somethings goes wrong in the test, the line in the graph will have some jerks
so i would like to be able to be able to point an arrow on the jerk with some customs texts.
i tried using notation on the graph but it is not really what i wanted as it is like it is being fixed on the x-axis point and will only move depending on the y axis.
(2,650 Views)
hi 64865050,
  Yes,it is possible to put arrows on graph with text using annotations.Just learn how to add annotations on the graph.
Thanks and regards,
srikrishnaNF
Srikrishna
(2,647 Views)
Just to add some info:
The example you are looking for is called "Programmatically Annotate a Graph.vi"
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,638 Views)
