Arrays, arrays !!! Manipulating
Hello all,
Just a thing I don't understand :
I use a VI that returns arrays (1D and 2D).
I use it in a For Loop, so I get all the arrays when the loop exits.
1D arrays are stacked in a 2D array and 2D arrays in a 3D array.
How can I extract my 1D and 2D arrays in another VI ?
Bruno Colombet
Neurophysiologie et Neuropsychologie
INSERM E9926
Faculté de Médecine
27 Bd Jean Moulin
133385 Marseille cedex 05
(3,073 Views)
You can use Index array function, if you want to extract a
1D array from a 2D array, wire the 2D array to the input
and if for example, you need the first row of that 2D
array, wire a 0 to the index first value, add another index
value and disable indexing by right-clicking on it. In the
output, you'll get the first row of your 2D array, as a 1D
array. In case you need to extract columns, use the first
index empty and disabled, and wire the position you want in
the second. In a 3D array is the same but with 3 dimensions.
Hope this helps, if not, ask again.
Best Regards
Gorka Larrea
glarrea_1@hotmail.com
* Sent from AltaVista http://www.altavista.com Where you can also find related Web Pages, Images, Audios, Videos, News, and Shopping. Smart is Beautiful
(3,073 Views)
