Array to Cluster
I have 4 boolean elements in an array. And also I have a cluster which has 4 boolean indicators.For writing the array into cluster, I need to convert from array into cluster. But Its not working out.It shows error like output of array to cluster function has 9 cluster elements but sink cluster has only 4 elements. Can you help me?
(2,500 Views)
Accepted by topic author sowshankar3007
Right click on the Array To Cluster function node and select something along the lines of  "Change Cluster Size". A dialog opens that allows you to change the size from the default of 9 to the size you want.
Rolf Kalbermatter  My Blog
(2,469 Views)
