Array problem
Small question about arrays:
See attatched problem.vi. How can I add the values to the array, not only change the value at index 0 each time I press the button.
Message 1 of 8
(4,160 Views)
Plz attach in LabVIEW 7.1 version or paste a pic of block diagram
regards
Dev
Message 2 of 8
(4,153 Views)
I have only Lv 7.1 version, can you resend that code plz?
Message 3 of 8
(4,152 Views)
Sorry, my LV8 is not installed by now....
To attach one value at index 0 you can use the build array function. Top input is your new value, second your array.
BUT try to avoid the build array function if you don't do once in a while since it will allocate new memory and costs system performance on big arrays.
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 8
(4,152 Views)
Here is 7.1. Sorry about that 😉
Message 5 of 8
(4,151 Views)
Hi Christian,
here u are!
In the attached VI, just see how i am insertig new elements into an array
Use either Build array or insert into array
Use build arrays for large arrays with care,  as it will load ur memory
Regards
Dev
Message Edited by devchander on 12-16-2005 03:24 AM
Message Edited by devchander on 12-16-2005 03:27 AM
Message 6 of 8
(4,146 Views)
here you go
Henrik
LV since v3.1
Message 7 of 8
(4,141 Views)
Thanx. That was quick Smiley Happy
Message 8 of 8
(4,132 Views)
