Array of hexadecimal strings to array of unsigned long integers
Hi GerdW,
That is helpful, however, I'm starting with an array of strings with each element of the array being one of the inputs (so element at index 0 s 100). How do I go from that array of strings to just strings separated by carriage returns to be able to use the "spreadsheet string to array" function.
Thanks, sorry again for being unclear!
Message 11 of 13
(539 Views)
As requested long ago, please re-post your VI, but this time with the typical default values in the controls. (fill controls with values, e.g. your 100s with the right delimiters and display style, etc.), then right-click the control ...data operation...make current values default. Save and attach the VI once more. Thanks!
You should also define the general rules, e.g. what should happen in the input is not 100.
Message 12 of 13
(533 Views)
Hi MBen,
see message #3, when your input is an array of strings...
(Do you even read the answers you get?)
Message 13 of 13
(525 Views)
