Array of elements
Hi, i want to create a n-dimensional array full of data (string type). Something like attached file but a bit more advanced. I need to use while loop. Every time the column,row and input data change.
It would look like this:
first time a start while loop the input data should go to col 1, row1
second time input data to col 4, row 7
third to col 6, row 22,
and so on... i thking you understand the point.
in attached file i want to write string in every row.
Thanks for the answer,
Božidar
(4,363 Views)
Forgot to add converted file to lower version.
Here it is.
(4,359 Views)
Hi Bozidar,
two points:
- you have to keep your array in a shift register too (like your counter), otherwise you will forget previous data
- you cannot replace non-existing elements! You have to initialize that array (or the shift register) with a sufficient-sized array of empty strings...
(4,353 Views)
Here is the corrected file.
(4,343 Views)
Is there any kind of logical relationship regarding which row and column the data should be created in?
Best regards
Matej
/* A smart device is only as smart (stupid) as its programmer. */
(4,340 Views)
Thank you very much 🙂
Božidar
(4,339 Views)
