Array of clusters that has an array inside the cluster
Why does the UI need to show the raw parsed data?
Is the intent to be able to run some commands programmatically based on the contents of the JSON? You could update some combo boxes with values parsed from the json if needed. Perhaps a combobox to pick a command and when the command is picked another combobox updates to choose the value. Or multiple buttons that are updated as necessary to reflect the available options for a command, etc.
~ Helping pave the path to long-term living and thriving in space. ~
Message 11 of 11
(186 Views)
