Array indicators used with Teststand causing Labview to crash
A Vi I have written passes measurement data out via a 1 dimentional array however on trying to create a Multiple Numeric Limit Test Step with this VI within Teststand, Labview throws an exeption and closes. Labview version 7.1.1 Teststand 3.1
(2,587 Views)
Can you post the VI you created and a sequence file that calls it? When you were asked to specify the module, did you have TestStand create it or was it a VI that you wrote outside of TestStand? Did you assign the array from LabVIEW to Step.NumericArray?
(2,572 Views)
