Array, how to change from indicator to control?
I have a set of block diagrams which builds an array - user will input 10 integer numbers and these numbers will be stored in Array_A.
Now I would like to perform some arithmetic operation to Array_A, e.g perform addition on Array_A and a constant array Array_B.
But since Array_A is an indicator, how do I make it a control, before I perform the addition?
Message 1 of 9
(3,467 Views)
Hi Splee,
You can make use of the Local Variables of the Array Controls to write or read values to it. To create a local variable, just right click the control and click create local variable. But make sure you don't create any race conditions.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your Problem is Solved;))
Message 2 of 9
(3,466 Views)
Check this example. Don't use sequence structures like this in your program. I used it just to show you how the local variable works.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved;))
Message 3 of 9
(3,457 Views)
"The wire is the variable". Since you generate your data and wire the result to the indicator, you already have a wire with the "expected" data, don't you?
Think of the LV block diagram a little like a printed circuit in electronics. How would you pass on a signal from a given source to a measurement point (e.g. the indicator) and a following element like an OP?
Correct - a branch.
So go for it.
If the data is required within a loop, but different iterations and it has to change, use shift registers.
Variables are the least option you should ever think off (if at all.....).
thanks,
Norbert
Norbert
Expert: Geometry
Message 4 of 9
(3,453 Views)
Hi Norbert,
Thanks for pointing this out. I failed to read the post well enough that i posted such a suggestion. I explained here how to update a control with two different values (at different instatnces) and while creating an example for showing it, i unknowingly explained what you just stated (taking the wires to send data) 🙂
Thanks again..
Nitz
Message 5 of 9
(3,447 Views)
"user will input 10 integer numbers and these numbers will be stored in Array_A." "Array_A is an indicator"
You should never store anything in an indicator, nor consider the indicator a variable.
The wire is the storage and variable. The indicator is a window to see it's data.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 9
(3,425 Views)
Hi Yamaeda,
If on the front panel I have a numeric control to let user key in any number and I would like to store e.g the 10 different numbers the user key in, how would I do so?
I thought storing in an array indicator would be a natural solution. Could you please advise which method should be used?
Can a wire store a series of number?
Message 7 of 9
(3,417 Views)
Hi Norbert,
I am a novice and I don't understand how a wire can be used to store a series of data.
Could you please show me an example?
Thank you.
Message 8 of 9
(3,415 Views)
Pretty basic:
Message 9 of 9
(3,407 Views)
