Array element blinking property
I have been attempting to use the array element blinking property to have one element in an array blink.
Utilizing the SelectionStart[] and SelectionSize[], I can select the array elements, but only the last one that has been "edited" by the user is the active element. The attached sample is what I have been playing with. I am using Labview7.0. Is it possible to use the ArrayElement.Blinking property in this way?
(3,407 Views)
Unfortunately the SelStart[] and SelSize[] properties of arrays do not work well with Blinking properties. However, instead of an array, you can use Multicolumn Listbox control with ActiveCell and Blinking properties to make multiple cells blink.
Shakhina Pulatova
(3,378 Views)
