Array element attribute nodes
I quite often use attribute nodes for controls such as pull down selectors
to 'grey out' choices or progmatically change the pull down names etc.
However if I make an array of these pull down selectors, when creating an
attribute node it has options only for the array itself (dimensions etc) not
the elements within it.
Is there any way I can get to the actual elements attribute nodes when they
are in an array?
(4,972 Views)
first move your mouse over the element and create then your attribute
node. That should help.
Bye,
Alexander
In article <7obnbn$b4e$1@andromeda.camcon.co.uk>,
selectors
an
etc) not
they
> are in an array?
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(4,971 Views)
Click on front panel you mean? Brilliant! I've always created Attribute
nodes from the diagram so never discovered this trick.
I like this group!
Richard
ps Now to go and scrap the inelegant work round I implemented this morning
and do it correctly!
Alexander Salim wrote in message <7oc13p$740$1@nnrp1.deja.com>...
>Hi,
>Bye,
>Alexander
(4,971 Views)
Hello. Again on Attribute nodes. I am trying to create a Multiple
Selection Listbox (under List & Ring)whereby after a few selections were
made, and at any one time, each of the element in the string list array
will for example, blink when its turn is reached (not all selections).
Anyone uses Test Executive before? The same principle applies.
Thanks for the help.
> I like this group!
> Richard
> >Hi,
> >first move your m
> >Bye,
> >Alexander
(4,971 Views)
