Array dimensions keeps changing
@minmin1004 wrote:
Also, what would you recommend for indexing if not a constant?
Once you are appending rows, use "built array". No index needed.
Message 11 of 14
(765 Views)
Ok thank you! I'll definitely try that. Right now I couldn't attach the program because I don't have access to the program (there are limited number of computers with the program and someone else is using it), but when I get a chance I'll shrink the program down and attach it as a file. Sorry about the inconvenience.
Message 12 of 14
(762 Views)
That would be great. I am sure the fix is very easy.
Be aware that the weekend is coming up and there will be fewer users. I'll try to check in once in a while. 😄
Message 13 of 14
(756 Views)
In the process of shrinking it into smaller program I figured out what was wrong and the problem is fixed😂😅! Thank you for your help so far!
Message 14 of 14
(735 Views)
