Array data manipulation
Hello Experts,
I would like to seek your advice on the best way to go about this problem.
I have a stream of acquired voltage data that is going into an array. When I press the Start button, a test will start and the voltage will increase. After the test period, the voltage will reduce back to it's original value.
Question is, I would like to analyze the data by having the average value of the votlage during the test period and when it is outside the test period. How do I do this using the data in that array ???
Example of what I want:
Test Off .... Test On.... Test Off
V1                  V2, V3        V4
Average Test Off voltage = (v1+v4)/2
Average Test On voltage = (v2+v3)/2
(5,227 Views)
Use Delete From Array.
Jim
(5,215 Views)
Hello Jim,
Could you please provide me your VI ? Thank you.
Also, I just realize that perhaps Array Subset would be a way to go.
(5,210 Views)
  1. My image is a VI Snippet.
  2. You'd have to use Array Subset three times to do what one Delete From Array does.
  3. VI attached
Jim
(5,203 Views)
Hello Jim,
Thank you for your recommendation of using Delete from Array. It's useful.
However, in the end, what I did was that I put a case structure to store the data in two set of arrays for when the test is ON and when the test if OFF.
Cheers
(5,167 Views)
