Array data dissappearing
When I create a boolean case  i am producing an array when true is selected.  It is basically a hex string to binary conversion.  My problem is when I turn the case to false the binary converion dissapears.  This makes sense but I am wondering any advice to have the binary conversion data to stay even in the false condition.  Thank you
(2,658 Views)
Please attach your code. It is not clear what you mean by "disappear", especially since it apparently make sense to you. 😉
Depending on your problem, the solution could be a simple as placing the indicator terminal inside the TRUE case. In other scenarios, a shift register might help....
(2,654 Views)
creating an indicator inside the  case statement solves my problem.  i actually had the indicatior outside the case statement.  thank you
(2,628 Views)
