Array Shortcut Menu Dismissed Event
I have an issue with the "Shortcut Menu Dismissed Event" when I try to use this on an array element. This event appears only if the shortcut menu was previously activated from the egdes of the array (or from the Index Display). If I active the shortcut menu with the mouse over an element of the array, then the "Dismissed Event" will not appear.
Is there a way to solve this and make the event to trigger ?
I attached a vi to explain the issue.
(2,240 Views)
Hmmm... seems to work for me.
Bill
CLD
(Mid-Level minion.)
(2,212 Views)
Replicated in 2020 SP1. Seems like a bug to me. As far as how to get the event to trigger, my only suggestion would be to use a cluster with numeric elements instead of a 1D array. Then, you can add Menu Dismissed events for each element of the cluster and the events will trigger, see the revised VI. The typical size of your array might prohibit that option though...
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(2,205 Views)
How did you replicate the issue?  Whenever I right-clicked on an array element, the event seemed to trigger.  Did I do it wrong?  (LV 2020.)
Bill
CLD
(Mid-Level minion.)
(2,195 Views)
Right click on the array itself and you'll get two events, one when you activate the RCM, and one when you dismiss the RCM. Only the first event triggers when right clicking an element.
Redhawk
(2,191 Views)
Here's a workaround that uses dynamic registration to capture events on the array elements instead of the array,
(2,181 Views)
Nothing to add here but an interesting observation that bit me in the past. You probably already know, but just in case.
A rick-click Short-cut Menu Event also triggers a "Mouse Leave" Event for the Pane. I had a transparent control that I hid or showed depending on whether one was in the Pane or Outside the Pane. Right-clicking made it look like someone left the pane when they didn't.
mcduff
(2,168 Views)
