Array Selection Color
Hello, I am wondering if it is possible to change the color of the array selection propriety. I have been looking for all the proprieties and i searched in the forum but didn't find a solution yet.
Attached is an example of what I mean for array selection, I guess you know what I mean..
Thank you in advance!
Message 1 of 12
(6,377 Views)
Use a table indicator and you have full control over the the background color of each cell, so use that. (example view).
Message 2 of 12
(6,362 Views)
I need it on an array because I have an array of clusters, I can't use a table. I thought there could have been some VI Scripting technique or something else but I guess it is not possible then.. 😞
Message 3 of 12
(6,319 Views)
I did some digging, but couldn't find any way to change the color.
Message 4 of 12
(6,311 Views)
As  said, you can adapt the table view to display the cluster (as text?) and convert it back to cluster-form when you're done.
Message 5 of 12
(6,303 Views)
@MPolaszyk wrote:
As @altenbach said, you can adapt the table view to display the cluster (as text?) and convert it back to cluster-form when you're done.
No back conversion is ever needed. Just keep the original data and branch into a dead-end for display processing.
Message 6 of 12
(6,298 Views)
what do you mean with "adapt the table view to display the cluster"? I don't understand but I upload a "array of cluster" version of my example and I hope you can edit it in order to show me what you mean.. thanks!
Message 7 of 12
(6,287 Views)
hi cassaniti,
a table can only have strings as its datatype (in fact a 2-dim-string-array is the value of a table)
what altenbach means is you could generate a string-representation of your array elements, but i don't think that is what you want.
another way would be to position something (e.g. a cluster) over a cell and adapting the cell size so it seems there is only 'something'.
i have done this with an enum, because i wanted a dropdown menu in a cell, but for your array of clusters this would be much more involved i presume.
a simple search found me this, perhaps that will take you further:
http://forums.ni.com/t5/LabVIEW/How-to-add-a-enum-or-a-boolean-to-a-specific-cell-of-a-table/m-p/287...
:cheers:
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 8 of 12
(6,279 Views)
If you wanted to do something so complicated, wouldn't drawing a coloured box around your array element be easier?
Edit: I've tried to find a suitable was to put a boolean as a string, but no characters that I can find with this snippet look particularly boolean. If you're ok with 'T' and 'F' or 'True' and 'False' or similar, I think the table is likely to be a good choice.
GCentralI'm attending the GLA Summit!
Message 9 of 12
(6,274 Views)
I think the suggested method is something like the VI I've attached. You'd need to also unpaint the cells when you moved away - I didn't implement this so unfortunately this VI just paints the table as you move around.
Message 10 of 12
(6,270 Views)
