Array Question
i have 3 1-D number array, each array has different array elements .Now i want to link the all the 3 array  elements one by one in order  to form a big size  new 1-D array. See the attached vi, how to do it ? Could you kindly help to modify it to let me understand it ? thanks.
(2,941 Views)
Just use the Build Array function. Wire the arrays to this function and then right click on the function and select Concatanate Inputs.
(2,938 Views)
