Array Problems
yes, thats clear, but what must i do to realy copy it to board?
Waht's the next step to upload it?
Message Edited by Phartas on 11-19-2007 06:45 AM
Message 11 of 23
(2,927 Views)
Hi Phartas,
just select the file by pressing "Durchsuchen"...
It will appear in the forum, when you don't preview the message. (This used to be a bug in the forum software, maybe this has gone with the latest update?)
Message 12 of 23
(2,915 Views)
ok, i hope that it works
Message 13 of 23
(2,911 Views)
So simple but no one says it easy
Message 14 of 23
(2,909 Views)
errhh, I can't open LV8.5 (until now)...
Message 15 of 23
(2,902 Views)
Not good!
can i downgrade the vi?
If so, please more detailed answers how it works Smiley Happy
Message 16 of 23
(2,899 Views)
Maybe you'd better add an image of the code that gives you a problem, and define your problem more clear.
What is it that you want?
It looks like you get the mean of element [1..4], [2..5],[3..6],  is that what you want?
Ton
My LabVIEW Ideas
Message 17 of 23
(2,898 Views)
Hi Phartas,
there should be a "Save for previous" entry in the file menu (unless you have a student version)...
Message 18 of 23
(2,893 Views)
OK,
i want the mean of 1-4,5-8, 9-12 and so on.
but that is not the problem not jet, but later.
the big problem is that the inner loop works silly.
The inner loop counts the pixel from the left to the right of the image. When all the mean of the 4127 pixel  in 4er step (nearly 1000 steps) are calculated than the outer loop counts the lines from up to down. So that i have the mean all pixel in 1x4 blocks.
My problem is now that the inner loop counts first 1 then the 2 and 3 step all at once. And it take so to long!
I hope that is more clearer.
i can convert to 8.2 and 8.0, tell me what you need.
and so first an image
Message 19 of 23
(2,889 Views)
Hi Phartas,
attached you will find an example to calc the mean of 4 consecutive elements of an array.
Btw. from my signature you see: everything except LV8.5 is ok for me Smiley Wink
Message Edited by GerdW on 11-19-2007 02:27 PM
Message 20 of 23
(2,885 Views)
