Array Looping?
Hii
 I am having an input array which contains two columns 1.Row Id 2. File Names
 Now the input file names contain the Looping operation....
 Now i want to repeat that files witth same Row ID ....
 How to do???
I have Attached the VI
Message 1 of 11
(5,362 Views)
I could not really well understand your description of the problem
Cand u please illustrate that section in a bit more detail?
Message 2 of 11
(5,345 Views)
Hii
 See i am having a 2D array which contain a row id and file names ...
 Now in between the file some looping will came by the time the the corresponding row id is empty...
 now for that loop we have to repeat the files how many time it should be...
 the row id have to be maintained as it is... in attached file..
Message 3 of 11
(5,341 Views)
I still don't understand....
Maybe if you give an example..
Message 4 of 11
(5,331 Views)
I think I understand the empty row part of the problem. When you hit an empty row, you want to repeat the next two rows twice?
Message 5 of 11
(5,313 Views)
Yes u are correct
Message 6 of 11
(5,303 Views)
I'm sure there are other ways to do this, and perhaps more efficient, but here is one.
Message 7 of 11
(5,284 Views)
look at attached VI
Hope you can build on the logic, using this VI
I guess you can proceed further using suitable array functions
Any doubts, do ask
Message 8 of 11
(5,282 Views)
Hiii
 Thankyou For ur help...
Message 9 of 11
(5,279 Views)
Actually ur array looping Vi is correct only but if i am give Loop to repeat for three times its not working properly...
Message 10 of 11
(5,275 Views)
