Array Data Manipulation
I have a very basic data acquisition program. The program reads a sine wave for 1 second and stores the read values as an array containing 102400 elements.
The frequency of the wave is 50 Hz so 1 cycle is contained within 2048 elements. I want to write a program that evaluates the average value over 1 second or 50 cycles. Any idea how to do that?
I tried using for loop but it's now working for me. can any one help me out?
Best Regards,
Mubeen Haadi.
(5,308 Views)
The problem comes when you are summing the arrays.  Look at the very first sum, and ask yourself what two things are being added.
LabVIEW is very particular about how it handles arrays.  If I add an array of size 5 to an array of size 10, how big do you thing the resulting sum will be?  If you are not sure, write a little LabVIEW program that does exactly that.  Once you see the answer to this second question, you can probably figure out why your sum is not working, and maybe even how to fix it.
Note -- I am deliberately not telling you the (relatively simple) fix.  Since you are trying to learn LabVIEW, finding and fixing the problem yourself will be much better for you in terms of learning.  However, if you are still having trouble, and especially if you did the simple "Add two arrays of known and different sizes" exercise, come back and explain what puzzles you ...
(5,290 Views)
You might want to rethink the average, and replace with RMS. The average of a sine wave will be zero or whatever its offset is, the RMS value is probably more enlightening.
mcduff
(5,288 Views)
I figured it out. needed to initialize the shift register with first.
(5,260 Views)
@mcduff
I was not interested in finding average of on cycle. that is obviously zero. I wanted to add the 50 cycles up and than find average such that at the end I have one cycle left.
(5,254 Views)
Yep.  By not specifying an input, you effectively used the "default" value, which is an empty array.  As you've discovered, adding two arrays of different lengths gives you a "sum array" whose length is the shorter of the two addends.  If one is an empty array, then the sum will also be an empty (length 0) array.
(5,250 Views)
That makes more sense. Sorry I misunderstood.
Here's another way, shift registers not required.
mcduff
(5,194 Views)
