Array 2D
Hi I have a 2D array (in the VI this is an example of 2D array). I want that for each column I read the first element of each columns and to subtract the first elements to all the elements of the relative column. For example I read the first element of the first column and I subtract its to all the other elements of the first column, then I read the first element of the second column and I subtract its to all the elements of the second column. This is a prove VI that I have created but I have no idea on how to obtain the new 2D array with all the new columns that I create with the subtraction of the first elements.
(4,012 Views)
I hope I have understood your problem, try this solution.
Let me know.
(3,984 Views)
Dear Ayanez, thanks for your reply. Can you give me an image or a VI with 2011 version. I don't have the last version of LabVIEW and so I can't see your VI. Sorry!
(3,940 Views)
Accepted by topic author Mark87
Try something like this.
(3,915 Views)
Thank you for your reply! You are a great person! I would like to Know LabVIEW as you! 😄
(3,904 Views)
Of course there are always several ways to do something. Here's a slight variation that might be even simpler.
(3,887 Views)
