Arduino & NI-VISA
Hi rockabilly,
some very basic error handling implemented:
(You don't need to wire default settings for VISAConfigure…)
Message 11 of 22
(1,559 Views)
What's this Green Box ? How to create it ?
Message 12 of 22
(1,552 Views)
A case structure.
When you wire an error wire to it, it changes to a red Error case and a green No Error case.
Message 13 of 22
(1,549 Views)
Same results, still drop to zero sometimes. May be because of the yellow line which i do not have and don't know its meaning and create
Message 14 of 22
(1,545 Views)
You mean the error cluster?  That is a very important piece of data you should be using.  It tells you if things went wrong somewhere and what the issue was.  A requirement for any good debugging.
Message 15 of 22
(1,542 Views)
Hi rockabilly,
Did you take all those free learning resources offered by NI?
If not: do it now!
Message 16 of 22
(1,543 Views)
Yes, that one in above screenshot 😞
Message 17 of 22
(1,543 Views)
Hi rockabilly,
to repeat previous message: you need to wire an error cluster to the case structure selector to get that green border.
Did you read the help for the case structure?
Message 18 of 22
(1,540 Views)
Yes i read but cannot figure since English is not my primary language. I changed the block diagram as below, but errors still continue. Fingers crossed...
Message 19 of 22
(1,532 Views)
Hi rockabilly,
Which errors do "continue"?
When you still get intermittant zeros in your indicators then those values are transmitted from your Arduino!
I do repeat: which string did you receive when your indicators do display the zero?
This is some basic code debugging on your side, so please do (or learn) that!
Message 20 of 22
(1,525 Views)
