Arduino Yun tcp/ip with Labview
Xbee? Zigbee?
Message 11 of 18
(3,583 Views)
What if I do not want extra component , just the arduino yun itself.
Message 12 of 18
(3,572 Views)
Have you read the specs for what you bought? You already said no to the built-in Wi-Fi so what else is there?
Message 13 of 18
(3,565 Views)
Oh so sorry . Right now I am using Yun's network . I am trying to communicate with my computer labview(client) to my yun (server). I tried to communicate  using TCP/IP but no data was recieved nor sent out.Here below is what I have done . Please guide me on where am I wrong.
Here is the code I used for my yun
i change it a little from the example
#include <SPI.h>
#include <Ethernet.h>
#include<Console.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
0x90, 0xA2, 0XDA , 0XF0 , 0X24 , 0X23
IPAddress ip(192, 168, 240, 117);
EthernetServer server(3477);
boolean alreadyConnected = false; // whether or not the client was connected previously
void setup() {
// initialize the ethernet device
Ethernet.begin(mac, ip);
// start listening for clients
server.begin();
Bridge.begin(); // Initialize Bridge
Console.begin();
// Open serial communications and wait for port to open:
while (!Console);
Console.print("Chat server address:");
Console.println(Ethernet.localIP());
void loop() {
// wait for a new client:
EthernetClient client = server.available();
// when the client sends the first byte, say hello:
if (client) {
if (!alreadyConnected) {
// clead out the input buffer:
client.flush();
Console.println("HI");
client.println("Hello, client!");
alreadyConnected = true;
if (client.available() > 0) {
// read the bytes incoming from the client:
char thisChar = client.read();
// echo the bytes back to the client:
server.write(thisChar);
// echo the bytes to the server as well:
Console.write(thisChar);
I am unable to send nor receive . HELPP!!
Message 14 of 18
(3,548 Views)
FYI .I am getting error 63 on my labview. Unable to send out data to my arduino.
Message 15 of 18
(3,539 Views)
How do you success of using it at the end?
Message 16 of 18
(3,310 Views)
Message 17 of 18
(3,268 Views)
were you successfull in doing it. I need to do the same. Kindly reply
Thanks & Regards,
Bharath Kumar
GCentral
Message 18 of 18
(3,193 Views)
