Arduino LabVIEW
Good morning, I have a problem conecting Arduino and LabVIEW. When I run in arduino's stardard software the blink example it works as it should.
However, when I run LabVIEW and I try the same it doesnt work, some leds light up (TX,RX,,L,ON), but the 13 leds doesent blink at all.
(I think I have installed all correctly but now I have doubts)
Thanks for your help
Buenos días. Tengo un problema con Arduino y LabVIEW, cuando ejecuto arduino en su software normal el ejemplo de "blink" me funciona correctamente pero cuando ejecuto LabView y pruebo este mismo ejemplo no me funciona aunque algunos leds si se iluminan (TX,RX,,L,ON)
Muchas gracias por su ayuda
(4,013 Views)
Hola ignaciogabaldon,
Me puedes decir las versiones que utilizas de labview para comprobar temas de compatibilidades y demas. Gracias
Te dejo un link bastante util sobre arduino y labview: https://decibel.ni.com/content/docs/DOC-16024
"LabVIEW Interface for Arduino FAQ"
Un saludo, que pases un buen día.
______________________________
Certified LabVIEW Developer (CLD)
(3,944 Views)
13th pin needs to be ON continously. If it shows in device manager in PC then it will be displayed on VISA too
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,930 Views)
Try resetting
--Ranjeet
(3,929 Views)
add other useful links, greetings
Getting Started With the LabVIEW Interface for Arduino
http://vishots.com/getting-started-with-the-labview-interface-for-arduino/
(3,870 Views)
