Applie Biosystem Analyst AAO Microsoft COM with Labview
Hi everyone, I need some help here for using Labview to interacting with Applied Biosystems Analyst software with AAO supplied with the software. If anyone familiar with the Analyst AAO please give me some direction. Should I call functions directly from the AAO.dll library or there are other methods to do so? I can only see four functions from AAO.dll. Thanks
Leimin Fan
(3,559 Views)
Leimin,
Here are some references for calling DLLs in LabVIEW.
1) How Do I Call a Dynamic Link Library (DLL) from LabVIEW?
2) When Does LabVIEW Load a DLL Called from a Call Library Function?
3) Writing Win32 Dynamic Link Libraries (DLLs) and Calling Them from LabVIEW
Hope this is able to help.
Sarah S.
Applications Engineering
(3,543 Views)
Hey Fanl,
I am trying to do similar work.  Did you ever have any luck writing LabVIEW to work with the Analyst Software?
(3,368 Views)
No, there is a bug in Labview that can not open AAO.  I worked with NI tech support for a while and could not resolve the issue.
(3,354 Views)
Thanks for the quick reply.  So I am curious, did you get around the problem another way or did the project fade away at that point?
(3,351 Views)
I have been forced to use VB.  The good thing is that the VB example program from Applied Biosystem helped alot.
(3,346 Views)
Good to know.  Thank you!
(3,336 Views)
