Application stalls
I have an application that takes in two analog signals (pressure and temperature, 4-20mA) along with 1 to 10 other analog signals (constant voltage signal from a switch)--switches under test.  The application records the pressure (and temperature) at witch a switch changes state (NO to NC and NC to NO), this work fine and I get nice txt files with all relevant data.
Problem.  I have been experiencing a delay in the signal shown on the front panel.  For example, when the pressure is declining there will be a time when the display pressure dial reads the same pressure for a period of 1 - 3 seconds.  This would not be a problem except if this occurs when the switch under test is changing state I may (and do not) get a true reading of pressure.  In fact, I can get a recording of all switches changing state at the exact same pressure; which is not the true case.  I also noticed that this application takes a lot of CPU power to run.
LabVIEW 9, Windows 7
Any suggestions or thoughts would be appreciated.
Brian
(2,676 Views)
Your use of the Write to Measurement File is incredibly inefficient, and to top it off, you are using 10 of them. Switch to a producer/consumer architecture at least. Do you see any problems when you disable all of the file writes?
(2,670 Views)
Yes, even if I test a couple of switches I observe the same behavior.
WOuld I use a producer/consumer loop for all 10, or is there a way to integrate all 10 into one?
Brian
(2,641 Views)
