Application "support directory"
Is there anyway to programmatically get the Application support directory as specified in the Application (EXE) Build Specification in an LV8.5 project? The one by default named "data". Currently I get the application directory, then build a path by appending "\data\whatever_file.txt" to get a path to a support file.
Michael
(4,072 Views)
What might be better is to create your own custom support directories in you build specs, this way you can ensure you always have the correct folder.
One thing to mention it is a bad habit to use string functions (with a '\' seperator) when dealing with paths. Building paths with the 'Build Path' primitive is platform independent:
Ton
My LabVIEW Ideas
(4,054 Views)
Custom support directories would work, it does seem silly not to be able to programmatically get the support directory though. Maybe I'll make a product suggestion.
I do use the Build Path primitive, thanks for the heads up on using the '\' seperator. I guess to make it platform independent I'll have to use two Build Paths to first build the support directory (data) then the filename(whatever_file.txt)
Michael
(4,026 Views)
Hi Michael,
you should check out the OpenG VIs.
With the Application Path I created the following VI:
It will return a path linked to the SupportFolder\ResouceFile.txt
On a LabVIEW development envirenment it will return the path to the LabVIEW x.x\SupportFolder\ResouceFile.txt file
Ton
Message Edited by TonP on 05-19-2008 07:22 PM
My LabVIEW Ideas
(4,008 Views)
