Application name in Taskmanager
is there a way to change the name of a labview application in the windows taskmanager.
Problem: I have written a labview application (compiled into an exe)  wich will be initialized with an ini File. I run this application in parallel (up to 8 times). Each application has the same name but loads a different ini. The Problem ist, that I now have 8 times the same application name in the taskmanager. If one crahses, I don't know which one I have to kick out of the taskmanager.
Is there a way to change the name of the application in the taskmanger?
Thanks a lot.
Michael
LabVIEW: 8.2.1
OS: Windows 7 / XP
(5,345 Views)
AFAIK you can't, but I believe you may try closing the application from the taskbar, provided that titles are different.
Another possibility is to get the app's Windows process ID and show it either on the FP or the title bar.
Process IDs can be viewed in the task manager. To get the ID, see the following, post #6 (thanks to myle00).
Paolo
(5,333 Views)
Hi Micheal,
instead of fiddling with Windows task management I would rather avoid crashes of my executables. 😉
(5,329 Views)
if it´s only up to 8 why not create 8 different executables with different names?
regards
Marco Brauner NIG
(5,305 Views)
Hi at all,
thanks a lot for the answer. I did it like Hans told and created 8 executables with different names.
Michael
(5,298 Views)
Because it may be a pain to update the exe if necessary. The technology in LV is available to run the same exe parallel, needs just 2 minutes to set up.
(4,010 Views)
