Application menu MAC OS
I try to remove, disable or customize the application menu of my LabVIEW application on MAC OS X. Smiley Frustrated
Have any idea to do this?
Cordialement,
Simon D.
CLA | Certified LabVIEW Architect
CTA | Certified TestStand Architect
(3,080 Views)
I have not looked recently but I think Apple has some minimum requirements on what must be in that menu and be functional.
Lynn
(3,077 Views)
Can't do that.
MacOS requires each application has its own application menu.  There may be nothing in there (as defined by the application itself) leaving just the system's services/show/hide/quit items.... but the menu will always be there.
You may be able to bump the program into a "kiosk mode" (if that's what they still call it) where the application takes over the computer like Front Row/AppleTV does.
(3,068 Views)
And do you think I can intercept event from this menu?
My problem is the quit option of this menu. In my application I have instruments, and I need to make some stuff before quit the application
I don't know this "kiosk mode" I will look this
Cordialement,
Simon D.
(3,059 Views)
Have you tried the event loop and the Application Instance Close? event?
Rolf Kalbermatter  My Blog
(3,055 Views)
Perfect it works Smiley Happy
I use Application Instance Close? and it's generate when I click Quit or Quit and Close All Windows. The other items are not a problem (hide window).
So I leave this menu, but just discard the quit option and use mine instead.
Thanks Smiley Wink
Cordialement,
Simon D.
(3,050 Views)
