Application cannot load runtime library when run from command line
I have built my first LabView application (on Fedora 5 Linux) which runs OK if launched from the Project Explorer, however if I try and run it from the command line it generates two errors:
1) Can't load LabVIEW runtime library /usr/local/lib/liblvrt.so.8.2
2) /usr/local/lib/LabVIEW-8-2/libOSMesa.so.4: cannot restore segment prot after reloc: Permission denied
Note: the runtime library is present in the location identified.
Can anyone shed any light on what I need to do to resolve these issues as I can't find any info in the NI website or in the documentation?
TIA
(3,764 Views)
Hi TIA,
Are you using a security management system like SELinux?
Sarah
Applications Engineer | National Instruments | UK & Ireland
(3,736 Views)
Hi Sarah
Thanks for replying and sorry for the delay - been on holiday 🙂
I am not running any security additions, just a vanilla Fedora 5 Linux installation.
Does anyone have any suggestions as to where I may look to solve this problem as I am at a loss at the moment.
(3,706 Views)
Just to close this thread, Sarah was right.
I did not realise that Fedora Core 5 installs with SELinux enhancements and this was the cause of the problem. Having turned off SELinux, my Labview application now runs from the command line as required.
Thanks Sarah
(3,694 Views)
