Application builder usage
Hello  Team,
I have Labview 8.6.1 Full development system in my PC but i dont have application builder for that version. I have Labview 8.5.1 application builder with me can i install that and make use for 8.6.1 version to make an installer to distribute.
Thanks In Advance.
(3,542 Views)
No, you cannot run the 8.5.1 Application Builder on 8.6.1
The Application Builder is a own Toolkit (but is included with LV Professional Version) and needs to be in the same Version then LabVIEW and to be licensed.
Christian
(3,531 Views)
Hello Rajeswari,
As you can see in the following link
https://www.ni.com/en/shop/labview/select-edition.html
Appliction distribution is not a feature provided with Full Development system for labVIEW.
Only Professional Development system and LabVIEW development environments which come with Developer suite provide this feature.
Mithilesh
AE, NI India
(3,503 Views)
Hello rajeswari,
 You can save the VI for version 8.5.1 (save for pervious version option) and use your application builder with labview 8.5.1 runtime engine(installed),build the exe and distribute.
Thanks and regards,
srikrishnaNF
Srikrishna
(3,492 Views)
