Application builder cRIO 2
     Dear,
I have a project which use the cRIO 9102.
There are: - the "main VI" one the Host computer
                  - One VI on the FPGA target: "FPGA VI"
                  - different subVI on the host
I would like created an application of the "main VI" with the Application builder. I work with LV8.5
I need some informations to realize this:
1 : Do I need to create an application of the "main VI" including other subVI to execute this application on an other computer which have not LabVIEW install (just Labview Runtime Engine)
2 : How to used this application with an other cRIO?
3: Is there a tutorial which explain how to created an application with a cRIO
Any help would be appreciated
Regards
  Massif
(3,372 Views)
I arrived to build the application but more document or a precise tutorials could be good for the user.
(3,326 Views)
Dear Massif,
Congratulations on building/deploying your first cRIO application. I am fairly new to the technology myself, and was surprised how easy FPGA and real time programming was. If you are still interested in furthering your knowledge, the national instruments website contains a lot of cRIO related information.
If, like me, you are relatively inexperienced with programming for cRIO targets, the following articles and tutorials are probably the most useful.
INTRODUCTION: NI CompactRIO – Reconfigurable Control and Acquisition System
http://zone.ni.com/devzone/cda/tut/p/id/2856
Tutorial: NI CompactRIO Project and Building Source Distributions
http://decibel.ni.com/content/docs/DOC-1697
CompactRIO Hands-On Tutorial- Basics I
https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview
CompactRIO Hands-On Tutorial- Basics II
http://zone.ni.com/devzone/cda/tut/p/id/3112
And finally, should you encounter and issues…
Troubleshooting CompactRIO Controllers in Measurement and Automation Explorer
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P70YSAS&l=en-US
Thanks for your time, and best wishes with your programming!!
Richard
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,310 Views)
Rich,
Nice summary of resouces....
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(3,302 Views)
  Dear RPR,
Thank you for all these documents.
To distributing the applications with "application builder" I used :
Distributing Applications with the LabVIEW Application Builder
https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
What Additional Files Are Required with an Executable Created with the LabVIEW Application Builder?http://digital.ni.com/public.nsf/allkb/E11297C4EECAB110862565A900648083
After to created the Executable:
How Do I Create an Executable Out of My LabVIEW FPGA VI?https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGjtCAG&l=en-US
Regards
       Massif
(3,288 Views)
