Application Web Server still requires IE for administration. What will happen with IE retirement?
When installing Labview, Application Web Server is automatically installed (without a clear notice), that is not needed by most users. Its default port (8080) may conflict with other web applications using the same port, that can be quite confusing when one is not aware of the issue.
Unfortunately, changing the port or disabling the server requires to access port 3582 on localhost, with Internet Explorer only (it won't work with other browsers because the administration page relies on a Silverlight plugin, not supported by modern browsers including Microsoft Edge).
Besides, Microsoft announced that Internet Explorer will be retired on June 15, 2022.
https://blogs.windows.com/windowsexperience/2021/05/19/the-future-of-internet-explorer-on-windows-10...
Is there a plan from National Instruments to update the Web Server for access to modern browsers before the retirement deadline, or at least to let the user decide upon installation (e.g. with a checkbox) whether the Application Web Server should be installed or not, and with the possibility to change the default port.
(1,913 Views)
Accepted by topic author fducos
I am virtually certain that NI is aware that (a) Silverlight is going away, (b) IE is going away, and (c) several aspects of "Classical LabVIEW" depend on Silverlight/IE for Web stuff.
NI is also aware that Web applications are extremely important, going forward.  While I have not experimented with LabVIEW NXG, it is my understanding that it used some other technology to provide Web Access and Web Support to LabVIEW NXG.  As you may be aware, LabVIEW NXG is also "going away", but the Good News is some of its features are being added to Classical LabVIEW.  I would expect you'll be seeing some of these when LabVIEW 2021 debuts (in about a month, I think).
So don't panic (yet) ...
(1,874 Views)
I think NXG will live on in the form of the NXG Web Module.  I think.
Bill
CLD
(Mid-Level minion.)
(1,861 Views)
Dear Bob,
thank you for your answer. I agree with you that hopefully NI must have anticipated this issue.
Let's wait and see.
Best regards
Fabrice
(1,781 Views)
